Последнее посещение: меньше минуты назад Текущее время: 11 сен 2026, 17:32
 [ Сообщений: 962 ]  На страницу Пред.  1 ... 82, 83, 84, 85, 86, 87, 88 ... 97  След.
Непрочитанное сообщениеДобавлено: 01 фев 2019, 13:18
А Скажите пожалуйста,коллеги,вот если отсюда https://archive.org/details/TheRadioAmateursHandBook_975/page/n59 по вытягивать Коллинза,Настольную книгу Радиолюбителя,это будет нарушением чьих то прав или нет?
Непрочитанное сообщениеДобавлено: 01 фев 2019, 17:56
Там в конце файла написано, что распространять можно, но если получить прибыль, то надо им 20% отдать:
DISTRIBUTION UNDER "PROJECT GUTENBERG-tm"
You may distribute copies of this eBook electronically, or by
disk, book or any other medium if you either delete this
"Small Print!" and all other references to Project Gutenberg,
or:
[1] Only give exact copies of it. Among other things, this
requires that you do not remove, alter or modify the
eBook or this "small print!" statement. You may however,
if you wish, distribute this eBook in machine readable
binary, compressed, mark-up, or proprietary form,
including any form resulting from conversion by word
processing or hypertext software, but only so long as
*EITHER*:
[*] The eBook, when displayed, is clearly readable, and
does *not* contain characters other than those
intended by the author of the work, although tilde
(~), asterisk (*) and underline (_) characters may
be used to convey punctuation intended by the
The Project Gutenberg eBook of The Radio Amateur's Hand Book, by A. Frederick Collins
http://ia700301.us.archive.org/13/items ... dm10ah.htm[10/8/2012 7:06:56 AM]
author, and additional characters may be used to
indicate hypertext links; OR
[*] The eBook may be readily converted by the reader at
no expense into plain ASCII, EBCDIC or equivalent
form by the program that displays the eBook (as is
the case, for instance, with most word processors);
OR
[*] You provide, or agree to also provide on request at
no additional cost, fee or expense, a copy of the
eBook in its original plain ASCII form (or in EBCDIC
or other equivalent proprietary form).
[2] Honor the eBook refund and replacement provisions of this
"Small Print!" statement.
[3] Pay a trademark license fee to the Foundation of 20% of the
gross profits you derive calculated using the method you
already use to calculate your applicable taxes. If you
don't derive profits, no royalty is due. Royalties are
payable to "Project Gutenberg Literary Archive Foundation"
the 60 days following each date you prepare (or were
legally required to prepare) your annual (or equivalent
periodic) tax return. Please contact us beforehand to
let us know your plans and to work out the details.
WHAT IF YOU *WANT* TO SEND MONEY EVEN IF YOU DON'T HAVE TO?
Project Gutenberg is dedicated to increasing the number of
public domain and licensed works that can be freely distributed
in machine readable form.
The Project gratefully accepts contributions of money, time,
public domain materials, or royalty free copyright licenses.
Money should be paid to the:
"Project Gutenberg Literary Archive Foundation."
If you are interested in contributing scanning equipment or
software or other items, please contact Michael Hart at:
hart@pobox.com
[Portions of this eBook's header and trailer may be reprinted only
when distributed free of all fees. Copyright (C) 2001, 2002 by
Michael S. Hart. Project Gutenberg is a TradeMark and may not be
used in any sales of Project Gutenberg eBooks or other materials be
they hardware or software or any other related product without
express permission.]
*END THE SMALL PRINT! FOR PUBLIC DOMAIN EBOOKS*Ver.02/11/02*END
Распространение в рамках "Проекта Гутенберг-ТМ"
Вы можете распространять копии этой книги в электронном виде, или
диск, книга или любое другое средство если вы или уничтожаете это
-Мелкий Шрифт!"и все другие ссылки на Проект Гутенберг,
или:
[1] только дать точные копии. Среди прочего, это
требует, чтобы вы не удаляли, не изменяли и не изменяли
электронная книга или это "мелким шрифтом!" заявление. Однако вы можете ,
если хотите, распространяйте эту книгу в машиночитаемом виде
двоичная, сжатая, наценка или фирменная форма,
включая любую форму, полученную в результате преобразования по слову
программное обеспечение обработки или гипертекста, но только покуда
*ЛЮБОЙ*:
[*] Электронная книга, когда она отображается, хорошо читается, и
* не* содержит символов, отличных от этих
задумано автором произведения, хотя Тильда
(~), Звездочка (*) и подчеркивание (_) символов могут
использоваться для передачи препинания задумано
Проект Гутенберг электронная книга рука книги радиолюбителя, по A. Фредерик Коллинз
автор, и дополнительные характеры могут быть использованы к
указывать гипертекстовые ссылки; или
[*] Электронная книга может быть легко преобразована читателем в
нет расходов в простой ASCII, EBCDIC или эквивалент
форма по программе, которая отображает электронную книгу (как есть
случай, например, с большинством текстовых процессоров);
ИЛИ
[*] Вы обеспечиваете или соглашаетесь также обеспечить по запросу в
без дополнительных затрат, комиссии или расходов, копия
электронная книга в своей первоначальной простой ASCII форме (или в EBCDIC
или другой эквивалентной форме собственности).
[2] почитать книгу возврат и положений замену
-Мелкий Шрифт!" заявление.
[3] уплатить фонду лицензионного сбора за товарный знак в размере 20% от
валовая прибыль, которую вы получаете рассчитывается с помощью метода, который вы
уже используется для расчета применимых налогов. Если вы
не извлекайте прибыль, роялти не причитается.
Роялти
к оплате "фонд литературного архива проекта Гутенберга"
60 дней после каждой даты вы готовите (или были
по закону обязаны готовиться), ваш годовой (или эквивалент
периодическая) налоговая декларация. Пожалуйста свяжитесь мы заранее к
дайте нам знать ваши планы и проработать детали.
ЧТО ДЕЛАТЬ, ЕСЛИ ВЫ *ХОТИТЕ* ОТПРАВИТЬ ДЕНЬГИ, ДАЖЕ ЕСЛИ ВАМ НЕ НУЖНО?
Проект Гутенберга посвящен увеличению числа
общественное достояние и лицензионные работы, которые могут свободно распространяться
в машиночитаемой форме.
Проект с благодарностью принимает вклады денег, время,
материалы, являющиеся общественным достоянием, или лицензии на авторские права без роялти.
Деньги должны быть выплачены:
"Проект Фонда Литературного Архива Гутенберга."
Если вы заинтересованы в предоставлении сканирующего оборудования или
программное обеспечение или другие детали, пожалуйста свяжутся Майкл Харт на:
hart@pobox.com
[Части заголовка и трейлера этой книги могут быть перепечатаны только
при распространении бесплатно всех сборов. Copyright (C) 2001, 2002 by
Майкл С. Харт. Проект Гутенберга является товарным знаком и не может быть
используется в любых продажах электронных книг проекта Гутенберга или других материалов
они оборудование или програмное обеспечение или любой другой родственный продукт снаружи
особое разрешение.]
*ЗАВЕРШИТЬ МЕЛКИЙ ШРИФТ! Для общедоступных электронных книг*Ver.02/11/02*конец
https://ia902703.us.archive.org/2/items ... ollins.pdf
А. Лизунков, вряд ли можно получить какую-то прибыль от распространения этой книги, да и по-любому из США до нас гутенберговы проектанты не дотянутся и санкции не введут!
Непрочитанное сообщениеДобавлено: 03 фев 2019, 12:05
Отсканировал Радиофронт 1932 №6 по максимуму (как обещал) на 600 точек, и упаковал в двух вариантах, сканы без обработки и после шумодава цветного шума.
оригинал
после шумодава
Размер файлов после шумодава меньше как в дежавю, так и если делать пдф. Но текст стал из ч/б темно-коричневым почему-то (в первый раз такое наблюдаю после шумодава).
ПДФ с сырыми сканами весит много, если распознать его, то в 1.7 раза больше, чем дежавю.
Могу попробовать сделать из цветных сканов черно-белый вариант или заново пересканировать в черно-белом, может размер файлов меньше получится (не уверен в этом, тут раз на раз не приходится).
Непрочитанное сообщениеДобавлено: 03 фев 2019, 16:18
На мой взгляд, после шумодава получилось почти что как до него, только немного хуже — изображение стало более плоское, как будто старая бумага выпрямилось и перестала быть шершавой —
рассматривать приятнее дошумодавный файл, и экономия 10 Мегабайт (давленный — 69 Мб, не давленный — 79 Мб) того не стоит, чтобы с шумодавом возиться.
А. Лизунков, спасибо большое, очень интересно — полное впечатление, что листаешь бумажный журнал, только пыли нет, и глазам легче — потому что на экране компьютера можно масштаб без труда увеличить
добавка:
у нас уже был этот номер в библиотеке в двух вариантах, но в худшем качестве —
http://lib.retrotexnika-forum.ru/?p=1860
а теперь я туда ваш скан (без шумодава который) тоже добавил…
Непрочитанное сообщениеДобавлено: 04 фев 2019, 11:00
Это так и есть, цветные шумы, к коим можно отнести и иллюзорный вид объемности бумаги, давятся (размываются), но фон с желизной в целом остается почти не тронутым. Использую шумодав исключительно с целью уменьшения веса исходных сканов, выигрыш составляет (даже не считая безпотерьной упаковки LZW или ZIP) для тифов примерно от 20% до 40%. Но времени тупая автоматическая шумодавка занимает много - для данного номера не меньше трех часов. В будущем не буду ее делать - время сэкономлю.
Так для этого и сканирую в максимальном качестве.
Я видел, там он разворотами был тоже в цвете отсканирован, но я не люблю читать разворотами, если они не составляют единое целое.
В следующие выходные попробую сделать ч/б версию в пдф, может весить меньше будет. Хотя не уверен, что хорошо получится, печать для 1932 года была неважная, слишком много просечек от шрифта в матрицах.
Непрочитанное сообщениеДобавлено: 10 фев 2019, 12:22
Вот черно-белая версия этого номера РФ в пдф, получилась вполне компактная, также сделал распознавание, но все же качество печати неважное и в целом на мой взгляд эта версия уступает полноцветной.
Непрочитанное сообщениеДобавлено: 10 фев 2019, 16:58
Распознавание это полезное дело, даёт возможность текст копипастить, но в данном случае старый разъеденный шрифт распознался лишь частично:
Покаэ р.аДиовр~ДитемЙ
Дово;rьно интересен отдел, [юкааывающий 'ра·
боту ,,~'ЮIN~rI'Ol,1O це'ХJа ОИ)!фСII:IOlПIС'~1Ъ'С>КОiГО ра,д.ноУЗ,11d. 3tJJЩ)Ь .да:ны дlH1a 1!I3!K'e"IJa. ПСIj.Ji13ЫЙ ~Ш!Rет поIШ3ЫВruс:т, ка-к 'геХIПIЧS'С~~И прав'Илыно надо не'СБИ
транслнц:ионную IlPOBO,;IlKY. Второй }!акет «Кто
И что мешает Iработе СИ11феJIЮПОЛЬ'СIЮГО радиоузлw» lJIШllБО,!ТёlС ЩрйШЗ';]<€IК{I,е:J1 БlШИ',ЫшШ'е посети'Т'е·леЙ
выставки. 3десь ,пре,дставлепы НEJпраВИJlьные СНмоволыньге ElКЛIOЧJеНИII а.бо'НЕJНТО'В в траIНС,ЛЯЦИОННУЮ линию. 'Гак нап:ри'.!е.р, тр-л 'I е}!чиров за·
зеl}llJIlI.;:[ лиrНИIIO, '11?'11 С3l)!Ы){ ВЫI\,ШО'Чlj~;I B'ro(JX СIЛ'ушателей, асш\! lП'реСПСII\ОЙНО елушал. Это ей"!.
не что и,ное, как еа,IOе ,откровенное вредительство в 'РaJ,иовещании. Гр-н ЦУТИ;IОВ сдела,л IЮрОТкое 3ЮIыкание через воду в стакане_ .мHO~O
с,лушателей не IГ\lе.1'И ВОi'JI,,!ожности в течение
целого ыесяца ,нользоватьсяпередаче.\1, Iпока на­
"юнец HIB о:тыс>кал:и этО'То радиовре'ДИТ'С1ЛН; гр-н
Татаренко СО'СI;Jал са,[ по IПlРИ1!ИТИВIЮЙ cxe~!e
Irрие,ши,к, включился в трансляционную линию,
иоп.ользуя ее в .Rачестве антенны, но включился
в О'ба П,роводшпса, чс,Oi! та,lсж,е зазе~[.J[ИЛ линию и
на,нес ущер<б радиовещанию. С пIQ]оБны>ш нвлеПI1ЮIИ 'радиослущатели д:олжны решите;rьно бороrься, Iбеапоща,дно разоблачая «iконтрабандистов
радиосеТII».
— это интересный кусочек текста на странице 7 про радиовредителей, один из которых устраивал короткое замыкание через воду в стакане :shock: жалко, не написано, как это может быть :?:
В чёрно-белом виде сканы становятся удобными для распечатки на бумаге, но вот лично я примерно в 2004-2005 гг. не мыслил чтение книг в электронной форме без распечатки на бумаге, а потом уже как-то привык смотреть на мониторах компьютеров, которые с тех пор стали не кинескопные, а жидко-кристаллические, с повышенной контрастностью, и теперь даже текст на сайтах делают тёмно-серый по белому, чтобы глаза сберечь, или фон делают не белым, а светло-серым (понижают контрастность),
так что выбеливать фон текста теперь не очень нужно, цветные менее контрастные оригиналы без какой-либо обработки смотрятся на ЖК-экранах лучше всего.
А. Лизунков, лишь бы разрешение было повыше, лучше всего 600 точек на дюйм :loveis:
Непрочитанное сообщениеДобавлено: 10 фев 2019, 18:50
Чёрно-белый вариант не понравился.
Больше всего понравился цветной без шумоподавления. Он как-то больше похож на настоящий журнал.
Что касается объёма, то мне абсолютно всё равно, что скачивать. Будет это 2 секунды или 10..
Непрочитанное сообщениеДобавлено: 10 фев 2019, 22:14
В ч/б варианте картинки как кажется более четкие, разборчивые.
Непрочитанное сообщениеДобавлено: 11 фев 2019, 09:06
Увы, эта беда для почти любых довоенных журнальных изданий, да и для ряда послевоенных тоже. Распознавание делаю большей частью для уменьшения размера пдф, в автомате, предлагаемом акробатом, естественно без какой-либо вычитки и коррекции. И соответственно наличие межсимвольных засечек в набранной типографской матрице и прочих дефектов печати резко снижает качество распознавания.
Там 600, имхо больше 800 для любых советских изданий нет смысла больше делать, линиатура печати ограничивает. Ну разве что когда нужно восстановить утраты в имеющемся экз., напечатав их, или же увеличить фото опять же для последующей печати... Качественную печать в журналах СССР встречал только в изданиях конца 80х или когда глянцевые жрналы печатались для других стран (типа "Наука в СССР"), вот там да, там можно сканировать и в 1200 и потом распознавание будет очень качественное.
На любителя, коих много, к сожалению.
Также очень много желающих иметь тоже самое, но в компактном варианте, даже с сознательно заниженным качеством скана. Например, фотоматериалы и полутоновые иллюстрации "умельцы" уродуют в дежавю, понижая разрешение до 150 точек или вообще приводя к монохромному варианту.
Резкость при переводе цвета в полутона немного увеличивал, вот и четче выглядят.
Сейчас этот форум просматривают: Bing [Bot], ClaudeBot [Бот Клод], ew7dk, дмитрийс и гости: 68
